opinions please? | on ElectriciansForums
Discuss opinions please? in the Green Lounge (Access Only) area at ElectriciansForums.net
Hampshire
Ok, need to bounce ideas about if poss....
Existing building with 3ph TT supply (100mA RCD, non -S type), feeds another building 300m away with a 3ph sub DB (no RCD) where my customer is looking to fit a 50kWp PV feed to.
We're waiting on Ze values on the incomer. I have no other info at the moment.
Thoughts/concerns with feeding the PV into the sub DB?
all depends on the CSA of the cable feeding the sub db, if that's ok for a 300m run then go for it, but maybe up the RCD to 300mA if that's ok for all other reasons.
Reply to opinions please? in the Green Lounge (Access Only) area at ElectriciansForums.net
