Discuss Options for replacing this antique? in the UK Electrical Forum area at ElectriciansForums.net
Has some idiot rammed proteus crap in there?
Reading the title of the post I thought it was about Telectrix ! I suppose if you're stuck and there's enough space you could fit an external 30ma RCD in a 2 module enclosure ? Not ideal though.
Seeing as that board looks a bodge with a Wylex RCD and Proteus MCBs and a current rating of 60a a new CU is probably the best option.
keeky chunt.
take a lot more than that to offend me. along with pete999. i know i'm an antique, but like a good wine, i improve with age. :33:I hope I didn't cause any offence Tel !:smiley2:
I've not seen that kind of board before but I have replaced those type of RCDs before in the old wylex boards. A standard Rcd fits but you also need a wylex adaption kit which contains new wire links and half blank pieces as full ones won't fit in the space as the new RCDs are slightly smaller.
Not sure it will fit your board as I say I have only swapped them out in the old wylex split load boards. The ones that had the colour tabs on the breakers
I pulled a 30mA RCD out yesterday that will fit that pile of junk!
i took it out this yesterday.
Reply to Options for replacing this antique? in the UK Electrical Forum area at ElectriciansForums.net
