Ordered new breaker and want to make sure it matches the current breaker in the breaker box that needs replacing. | on ElectriciansForums
Discuss Ordered new breaker and want to make sure it matches the current breaker in the breaker box that needs replacing. in the USA Electrical Forum area at ElectriciansForums.net
San antonio
I ordered the exact breaker that is in the breaker box and they sent me this one. I want to verify that it is compatible with one in the breaker box. I took a picture of each. Thanks in advanced the company won't answer their phone so I'm kind of stuck until I find out!
[ElectriciansForums.net] Ordered new breaker and want to make sure it matches the current breaker in the breaker box that needs replacing. [ElectriciansForums.net] Ordered new breaker and want to make sure it matches the current breaker in the breaker box that needs replacing.
@ryansteeldavi yes that will fit but what you bought was a single pole 1 inch breaker. The breakers I looked at in the panel was one 1/2 inch breakers which means take that one back and buy a slim line or 1/2 inch breaker or what ever call them. They make them so you can have 2 loads in place of a standard breaker
[automerge]1569611114[/automerge]
View attachment 52643 View attachment 52644
[automerge]1569611430[/automerge]
That looks like a GE breaker go to Home Depot who sell them all day and show them these pictures but since both breakers are off pull out that breaker and take it with you CUT OFF BOTH BREAKERS before you remove it
Take the old breaker with you it might be one breaker with 2 breaker switches
So I could be looking for a breaker with two switches instead of the original one switch?
[automerge]1569620802[/automerge]
Are they're specific numbers or a code on the breaker I should be looking for?
Yes and whatever the amperage
[automerge]1569622541[/automerge]
Check the stapes behind the breaker like horizontal par parallel
[automerge]1569622640[/automerge]
It’s probably vertical staves in back of breaker
No I still haven't been able to locate a copy of it at home Depot does anyone know which numbers specifically I should be looking at. I'm trying to find a match to the original in the box but I can't find one online or in store. Maybe I'm not looking at the right thing. But I'm going based off numbers in the front
What’s the brand name like GE, OR Square-D or some other name
So what the man at home Depot just told me is that I have the right one it's just a different brand. Is this correct? The original one in the box is from 2001 and I read it's hard to find them nowadays. This is the same exact size and style same amps except this says 1 pole j-969 the original says sr-100
[automerge]1569630391[/automerge]
I'm not sure of the brand of the original but the new one I have is eaton
[automerge]1569630592[/automerge]
So the original is T&B a product of Challenger. When they were around I guess
Due to company’s going out of business breakers are interchangeable and it sounds to me like you have the right breaker put it in and let me know please
[automerge]1569630822[/automerge]
I’m assuming it had 2 screws use like the one you are replacing.
Thank you! I'm going to do it now I'll get back to you with results.
T&B made breakers that were UL classified to be used in competitive panels, the Eaton BR, C, breaker pictured is also UL classified to be used in competitive makes, the T&B breakers are no longer made. The UL listed/UL classified situation can be a pain, & Eaton makes classified breakers to fit other makes, plus Siemens & Eaton both make a UL classified breakers to fit some Square D QO loadcenters, but just because a breaker fits does not mean it can be installed, there needs to be paperwork proving that it is OK to use, which makes the whole situation clear as mud.
GE twin breakers cannot be used in any panel other then GE, due to their unique design.
T&B no longer make breakers but the UL listed replacement breaker for T&B is Eaton
Reply to Ordered new breaker and want to make sure it matches the current breaker in the breaker box that needs replacing. in the USA Electrical Forum area at ElectriciansForums.net
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
