A
acat
Hi Folks
Got a job the other day and was assured they had everything they needed as they had already been advised what was required. (Should have smelled a rat at this stage).
Turned up today to find that it is a new supply in a shed from another out building asked for the bits and pieces they had and was given 4mm swa cable a socket and a light. No glands, no clips, no CU for the shed and no MCB to run SWA from CU in outbuilding. Turns out the expert advice came from a chippy???????????????
My problems are never dealt with SWA before, location is a farm where their is no vehicle or livestock access. What is the furthest distance recommended for unsupported SWA overhead or can this be just laid on the ground.
Any suggestions appreciated
Chris
Chris
