It's a pme system with CU in property, having 100a rcd with mcbs. No extraneous conductive parts in shed.
Good answer, ta.
Discuss Outdoor Consumer Unit in the DIY Electrical Advice area at ElectriciansForums.net
Well it's a 100a main switch with 2 rcds and mcbs lol.Good answer, ta.
Thanks, I was only installing an outdoor CU (Ip65) as had been advised by sparky (called for quote) that's what he'd need to do so there was a point of isolation between house CU and shed.Can't see why you want 3 CUs. An outdoor socket does not require an outdoor CU. Even a shed does not require its own CU. Run the cable in from a spare way on the house CU direct to the sockets and the lights via a switched FCU.
Reply to Outdoor Consumer Unit in the DIY Electrical Advice area at ElectriciansForums.net
