Would I be right in saying that adding an outdoor PIR to an existing outdoor lighting spur with one existing PIR and two post lights on it would not be notifiable anymore since April 2013?
Also the house has a 3036 board which I will be recommend updating however I'm fairly certain that will not happen. The outdoor lights are fed from a fused spur inside the house off a ring final circuit. My understanding of the regulations is that if you are modifying an existing ring final circuit then RCD protection must be provided at the origin of the circuit. Adding an RCD fused spur only protects the modified part of the circuit, would this comply?
