Outdoor power cable routing... | on ElectriciansForums
Discuss Outdoor power cable routing... in the Australia area at ElectriciansForums.net
H
House_Hunter
So planning on running a cable from the house down the garden to supply power for some garden lights.
I am planning to route the cable through some black MDPE pipe (highlighted to state electrical wires inside).
My question is:
Should I drill holes in the pipe to let any fluid get out?
I don't like the idea of the cable sitting in water if some water got into the pipe conduit.
What are peoples thoughts?
Cheers!
Many thanks....fully aware of certification requirements. Which are all ok.
Thinking of using 32mm MDPE pipe running 3-core 2.5mm inside; either NYY-J cable or SWA depending on whtehr I am able to dig a trench or need to surface route.
Drilling holes in the bottom of the pipe will allow water out, but it will also allow water in as the water table rises. I would also suggest that you bury the cable/pipe at least 300 - 450mm deep (beyond spade and fork depth) as an added safety measure. As to the type of cable for this job (and in my humble opinion), a 3 core SWA everytime.
I posted the link to NYY-J in reference to your post about HYY - which I haven't come across before....
Agree...will be almost impossible to stop water getting in....which then leads me back to the original question - should you have drainage holes?
What have other people done? Do you care about your SWA potentially sitting in water?
No you can bury SWA direct in the ground without feeding through a pipe. That's why the majority of time it is most sparks first choice of weapon.
I have seen, if you want to do it. extend the pipe about a foot above ground level each end of the run, Fix it to the wall with a clip, SWA clip is good and dollop some silicone in either end. It,s not perfect and over time it can effect the PVC of the cable but not sure if NYY-J will be that affected. Most time when you use pipe for drawing in cable it normally terminates inside a man hole or a chamber.
Fair do's.....cheers for the advice.
How easy is swa to terminate in say a light fitting though? Heard it can be a pain....if not impossible!
Would seem a little messy to have a swa run to a JB, then NYY-J from the JB to the light? Surely must be a neater solution?
Don't forget that you will want to then run the SWA on to the next light point, assuming you are having more than one light. If you do, don't forget to fit the banjo's inside the adaptable box to the SWA's and connect the two with 4mm earthwire
Reply to Outdoor power cable routing... in the Australia area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
