Hi Guys,
I will be re-fitting 10x (Mains voltage) Mini LED stair lights. The existing LED's have drivers and are all wired back to (what should be) an IP65 rated enclosure which is fed from a switch at the front door via a 1.5mm 3 core SWA cable, glanded off through the enclosure into a Switched spur with a 5a fuse.
Question: Do I need to fuse the supply to these LED's or can I do away with the Switched spur??
