Outhouse | on ElectriciansForums
Discuss Outhouse in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a client asking for her freezer and tumble dryer and light to be sited in the outhouse. Old uninsulated outside toilet with store next to it.
easiest way is to SFCU from the nearest ring socket in the house, but the current draw is going to be too much.
not so easy is run cable from cu externally around house into outhouse.
hard way run cable from cu up into loft across house out of loft down wall and into outhouse.
Can I unfused spur off nearest ring socket in 2.5mm through into outhouse, double socket(RCD) in outhouse, freezer and tumble dryer plugged in, FCU off that socket for light with switch? Will this meet regs?
many thanks for any advice.
Spikenaylor
you could come off a |RFC socket to a 20A MCB ( in a suitable enclosure) then to the outhouse. double socket then FCU ( 3A) to lighting.
Reply to Outhouse in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone, If you are looking for reliable EV chargers, check out our top-rated selection at E2GO! âš¡ Please note that all EV Chargers and...
Haha yes, it is. Must be a northern expression. Have a Google 😂
The 3A fuse is there to protect the current lighting. For additional power you connect from the non protected 3A fuse side.
