outlet pillars | on ElectriciansForums
Discuss outlet pillars in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Doomed
Dorset
I have been sent to inspect a caravan park the company I work for has been looking after for years.
Immediately I see that each output pillar for the pitches has one RCD covering 2 mcb's and thier sockets.
I believe that this is not on (708.553.1.13)
As our company has inspected this site for the last few years and not noticed, and as these pillars are off the shelf units is there any way around this issue that does not cause the company I work for to lose face (and me p155 my boss off big style)
Just recommend that it does not comply with the current regulations which have recently been updated and that the recommendation would be to get the pillars upgraded when possible. Overall it is not a major danger just a nuisance since two caravans could be affected by a fault on one.
Reply to outlet pillars in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I guess the easiest way would be to run a supply from ignition /aux via a relay that drops the supply when the lights are on.
I recall where a fluorescent capacitor would cause a separate socket RCD to trip when turning off the light
