T
TarkMalbot
Hi,
I am currently helping out with some outside arena lighting and have a dilemma to consider. Basically the issue is the first of eight circuits has been wired in single phase but using the grey sleeved as green & yellow and the black sleeved blue as Neutral. Now I know that it should be the other way around although apparently not law but advised by the NICEIC etc to de-associate black being used as neutral blah blah blah, but the 16mm SWA tails used are now too short and awkward to swap over in the distribution board and in the fused cut outs. My question is should I have the other 7 circuits wired in using the same "not quite right" coloured cores but correctly sleeved or have the other 7 circuits wired in using the black sleeved as earth and the grey sleeved blue for neutral which is the proper way to do it but will have one circuit different from the rest?
All the posts are being put up and the cables pulled in by the owner, I designed the system, am overseeing the work including the wiring and then a local company is coming in to test, inspect, connect up to the main incoming supply and sign it off. I just wanted to ask on here before continuing and to try and limit any more embarrassment after this initial mistake. The cause of the mistake was that the distribution board is fed by a red, yellow, blue and black TP&N supply using the black as neutral so common sense was used to put the black sleeved as blue to be the neutral, brown as live and grey as CPC.
There is a warning on the DB before anyone mentions it.
"This installation has wiring coloursto two versions of BS 7671.
Great care should be taken before
undertaking extension, alteration or repair
that all conductors are correctly identified."
Photos below show un-sleeved but you get the idea:
Thanks for any advice and any questions please ask.
Mark.
Mark.
