Hey guys .. I'm running a new circuit to a large outside area in a garden , consisting of 5 heat lamps 250w each ...
I've done the calcs and it will.be pulling 5a . Cable run is only 15m
Are there regs on outside heater lamps in the 18th ?
And
Would 2.5 armoured on a 6amp MCB be ok ?
Would you install a double pole isolator outside ? ..
And
