B
big-ed
Hi all,
I have fitted an outdoor socket, drilled a 12mm hole through the brickwork & ran white 4mm 2C+E fp200 from the outdoor socket to inside the garage into a surface mounted 20A IP rated switch.
From the IP rated switch I have ran the cable to my smaller garage consumer unit & fitted it with an main RCD & a 16A type B breaker.
Do I need to get this Part-P certified?..
