Outside light second fix missing 240v | on ElectriciansForums
Discuss Outside light second fix missing 240v in the UK Electrical Forum area at ElectriciansForums.net
Leeds
Returned to install/second fix led pir flood, switched live hidden in kitchen cupboard to over ride, did all connections, worked perfectly, went to check night time performance and nothing, for some reason no voltage going to the switch live in the kitchen cupboard, nothing tripped, everything else all okay?
You need an electrician. (Sorry)
Reply to Outside light second fix missing 240v in the UK Electrical Forum area at ElectriciansForums.net
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
