outside light stopped working?? | on ElectriciansForums
Discuss outside light stopped working?? in the Australia area at ElectriciansForums.net
W
watson789
Hi all
i have a problem with my outside light. i am doing a bit of moving around near the consumer unit and have put a new on/off switch on - this has 2 switches 1 for the back and 1 for the side light both worked fine before i put any new switches on.i switched the consumer unit off i then snipped the wires shorter (as i was moving the wire to a closer point) and then shuffled all the wires back a little into the conduit. i tested the on/off switch and it worked fine and so did the lights (both of which are on a sensor)... i then went to switch them off at the consumer unit again to tidy up and screw everything in.
5 minutes later i go to switch them on and the back floodlight comes on but the side light doesnt - i have tried switching the switches round and the back still works but the side doesnt come on!
help!!! i am out of ideas - i have looked around and cant see anything wrong, i have checked the switch with a neon screwdriver and there is current flowing through it ( on both switches)
does anyone have any idea why the side light has suddenly stopped working???
have been and checked every connection to make sure there is noting loose, i have tried a differnet switch and also tried it again when not secured into the back box and still no luck!
its strange because the switch is a 2 way double pole and 1 switch is connected to the back floodlight which works fine in which ever switch i place it in but the side light doesnt seem to work in either!
im totaly puzzled... is ther anything really simple im missing???
i havent touched the sensor for while espercially not today.
Try putting the switched side for your side light into the feed side for your back light.
Do you need to link a feed across between your 2 switches or have you 2 seperate feeds?
Reply to outside light stopped working?? in the Australia area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
Is it a retaining wall? If so I'm of the opinion penetrating damp is almost impossible to avoid. Make a channel underneath for runoff and slosh...
