Outside light wiring | on ElectriciansForums
Discuss Outside light wiring in the UK Electrical Forum area at ElectriciansForums.net
V
vikingbobw
Hi all, had an outside power socket fitted and want to know if it's possible to wire up a patio type light (wall mounted) and instead of having it hard wired in, using a plug to go in the socket. Firstly can it be done safely by non qualified persons, what equipment I need and any tips. I envisage fixing the wire down the wall ending up plugged into the protected outside socket. Speak slowly with hand gestures for this novice. Thanks for any advice.
Reply to Outside light wiring in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
