Outside light with PIR and switch | on ElectriciansForums
Discuss Outside light with PIR and switch in the UK Electrical Forum area at ElectriciansForums.net
J
jjrules2
Is there a specific name for a light that works by switching it on or off at a switch in the house, as well as coming on when someone walks in front of the PIR?
I have aver wired outside lights in 1.5mm 3c and earth and struggling to find a nice up/down modern light with the permanent live, switched live, neutral and earth connections! Baffles me but all the good ones just have L N and E
use any light that you want with a separate PIR. from supply, feed L and N into switch position, 3 core /E to PIR. then T/E to light. i'll leave you to draw it out so that the PIR has a permanent feed and the switch will override the PIR to light the light. good practice to use a SFCU with 3A fuse for the supply, then on to the switch etc.
You could try the DIY forum
Reply to Outside light with PIR and switch in the UK Electrical Forum area at ElectriciansForums.net
Some pir lights have a switched output so you can link them together, when any pir is activated then all lights will come on. if you don’t connect...
