I
irishsailor
Guys
A quick question, I have an outside light controlled with a switch inside, iI has sensor fitted which works.
However when I switch the light on from the switch it flashes on and goes off once amd then the sensor works fine is this a loose connection or is it a timing issue??
Also the lighting circuit is on a BS3036 5A fuse what sort of Zs reading should I be getting?? Do I need to remove bulds etc to do a Zs test??
Regards
Chris
Regards
Chris
