Outside Light | on ElectriciansForums
Discuss Outside Light in the DIY Electrical Advice area at ElectriciansForums.net
soborski2015
Hi there,
I want to have a outside light fitted to the side of my garage, I also want to operate this light with 1 switch inside my garage and one switch inside my house.
What are the best ideas you guys can come up with where i could get my live feed from without setting up a new circuit on the CU.
thanks.
Reply to Outside Light in the DIY Electrical Advice area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
