Outside light | on ElectriciansForums
Discuss Outside light in the Australia area at ElectriciansForums.net
F
Frosty69
Hi people,
If I spur of the ring main to a switched fused spur to supply an outside 500watt floodlight, when doing IR test do I just IR the cable I have put in (from socket to light)? Or the full ring?
Thankyou
I hope this isn't classed as a hijack! But.. has anyone tried alternative floodlights? Are they a decent comparison yet?
I can't honestly see a CFL type fitting with a PIR illuminating an area very well. A CFL fitting with photocell sounds reasonable however.
might pay the customer back in a century. they only on for a few minutes at a time. i'm referring to PIR switched floods. obviously if they are photocell or manually operatede and on for long periods, then i agree. but never found a cfl gie more illumination than a good candle.
Reply to Outside light in the Australia area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
Is it a retaining wall? If so I'm of the opinion penetrating damp is almost impossible to avoid. Make a channel underneath for runoff and slosh...
