A
adam1984
A collegue at work has asked about having a PIR light added. Not sure if im allowed to do it but said that i would have a look into it. The Consumer unit has no RCD and is the old wylex unit that is found in so many authority houses (meteral i think / skelton type)
my thoughts would be to take power from existing power circuit to FCU, drill through wall and run 1.5mm black flex in 25mm pvc conduit to light.
Will the light require RCD protection?
