P
Peter Woodford
Guys,
been to see a job the woman just wants a dimmer switch fitted in her bedroom. I take it i don't need to do a mw cert for this and how much would you charge as will only take 5 mins and its only 10 doors away. She also said later on she will want some outside lighting. In the shed she has a old fuse board which is backed up by a rcd in the house. The board in the shed only has 4mm ran to it as very sort run and supplies 2 single sockets and 1 light said i would break into the socket circuit and put in a switched fused spur come out of shed and fit in 2no light posts would then do a mw cert for addition to circuit but was wondering about the old fuse board do i need to carry out any tests on this ( has fuses). If there is a spare way on this board will run new circuit from there for lights
cheers
cheers
