Wiring up an outside socket , light switch and light all outside , under a covered way and attached to the house. All weatherproof obviously and in conduit , spur in the kitchen to the outside socket and then from the socket to a 3amp fuse (used as switch) and then to the light. Is that the correct way or is there a better way ? All help appreciated.
