W
walec
Hello All, I have just replaced an outside bulk head light for two PIR flood lights, looped from first light to second. All was fine, working as they should until the customer called me to tell me they were not working. Turned the breaker off and on for a quick check, sure enough not coming on when initially energised. Did not have my tester with me so checked power to lights with probe, 230V not problem. Turned the breaker off for a few physical checks as I bypassed the switch inside so they could not be turned off manually at the customers request, all connections seemed fine. Turned power back on they worked...waited for them to go off, turned power off and on did not come one, turned power off waited a few minutes, turned it on and they lit up. So basically if you turn the breaker for a few minutes and then on, they will work on the initial surge. I will go back with my tester tomorrow and test properly but I have not seen anything like this before! any ideas? Thanks
