K
kduck
Do you need an rcd for outside lights, the lights will be powered from in side the garage drilled though to the lights on the outside no wire showing. I would say yes it does need a Rcd, keep on getting different messages. Problem is there is no space left on the rcd side so I would need to fit a rcbo (cost)?. So just seeing if a need to rcd it.
Also on timber frame houses on the internal wall can you rod top to bottom of the walls (i.e first floor to loft area) or is there usually a noggin stop you doing this.
