Outside socket on a spur | on ElectriciansForums
Discuss Outside socket on a spur in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Stormflex
Morning all,
I have a customer who would like an outside socket fitted. There is a double socket inside their patio door.
Can I run this as a straight spur of the current socket or do I need to run it to a FCU first?
Rich
Good point. I have assumed it is on the ring. The ring is protected by an RCD.
malcolmsanford - are you saying that if the socket is in a ring I can't spur off of it?
if the existin g socket is on the ring, then you can spur off 1 socket without a FCU. if it's on a radial 16A cct. you can just add your otside socket. only if the existing socket is itself spurred off a ring do you need to fit a FCU.
HI Guys As you know i come from an It background and had thought that in the distant past they did allow a spur of a spur indeed the house i am in at the moment has one as did my previous place(until i had it fixed).
When did this practice stop and is it still acceptable as a old installation .
The one in my present house is a upstairs ring main with a non fused spur to a dbl socket which in turn has had three further doubles added after that one approx 10ft further on from the spur all looks tickety boo to my "non spark eye".(checked as best i can with my marindale and volt meter)
I use these sockets for low wattage equipment.
Should i be concerned and get it fixed or just leave alone as an old instal?
cheers 72-van
ideally you should fit a 13A FCU before the first spurred socket. this will limit the current drawn by your spur to within the capacity of the cable.
Hi Telectrix Thanks for that advice but were i to do that surely i would then be altering an old install and making it "illegal" my plan was to disconnect the extra double sockets which are connected after the original spaur part before selling the place thereby "keeping it right " to my non spark eyes.In the mean time the sockets are in use for devices that probably draw 5amps max between them & i am the only one living there.
Or should i bite the bullet and disconnect the spurred spur thing now and use an extension lead tp power this kit whats best ?
72-van
cheers 72-van
IMO I would fit it via a FCU for a couple of reasons. As said earlier with a switched FCU you can isolate the socket completely when not in use. Also if you ever want to work on it, you can isolate it via the switched FCU without turning off the whole circuit.
Saying that as long as it's just the one un-fused spur point off an existing ring final circuit or a radial there is no need for a FCU.
I was though in my OP more concerend about the RCD protection for this socket.
Reply to Outside socket on a spur in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Outside socket… ok. But you say the fcu for boiler is beside the outside socket… is the boiler outside too? FCU’s have an IN and an OUT… the OUT...
Many thanks. Very clear!
