Outside Supply | on ElectriciansForums
Discuss Outside Supply in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
Rammie
Hi
Been asked to relocate a domestic outside supply from a junction box on one of the house rings to a spare way in the CCU.
Does this require an EIC rather than minor works? And which tests should I carry out please?
Thank you
Rammie
Reply to Outside Supply in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It might be ok
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
