I
isitnow
Hi guys just wondering the best way to wire ovens and hobs, I usually see hobs on their own via a double pole isolator to the side of the hob and the oven plugged into a socket mounted inside the cabinet sometimes but i dont really like the thought of that, (although mounting equipment to fixed unremoveable kitchen panels is acceptable)
I know that all terminations have to be able to be visually inspected but just wondering if any of you guys have a better way rather than having to plug the oven into a socket outside the cabinets or mounting one inside the cabinets nearetst the oven,
I only ask as I am not a domestic electrician and the job is for my own home and i want the best job i can possibly do, I have considered wiring an sfcu (nice looking one) as part of the kitchen ring and running the flex from the oven directly through a conduit chased into the wall to a flex outlet cover fitted behind the oven so that the cable can be removed if the oven needs repalcing etc sounds pretty decent to me just need a heads up if theres a better way???? thanks in advance
oh and one of the reasons i ask is that the rented property i am living in now has combined the two via the double pole iso and its a brand new build so i assume it shouldve been wired correctly.
