Hi all,
I have a dedicated cooker circuit on a
6mm cable, 32amp mcb running to cooker switch down to connection plate.
I want to install a 1kw ( just under) oven and 6kw hob! Am I ok swapping the connection plate for a dual one and connecting together??
And if so do I run 6mm flex hob to connection plate?
And 2.5 flex oven to connection plate?
Or do I have to use 6mm cable for both
Thank you
Thank you
