Oven and hob wiring | on ElectriciansForums
Discuss Oven and hob wiring in the Australia area at ElectriciansForums.net
I
Ionkontrol
Hi,
1st post and a question for you pro's.
I am renovating my kitchen at the moment and am putting in the back boxes for for sockets.
Electrician will do all final wiring.
Currently, my dedicated cooker circuit looks like this.... (actually 32amp not 30)
My new oven is a Siemens single oven rated at 3.3kw.
The instructions say 'do not connect with a 13amp plug or restrict with a 13amp fuse'.
My hob is gas with a 13amp plug for the ignitor.
Can the hob and oven be connected to this circuit and should I put in a double back box for this installation and what would the front plates be? Hardwired flex outlet for oven and 13amp socket for hob?
Alan
Reply to Oven and hob wiring in the Australia area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
Since my last post I have used the oven several times and it is still working ! On reading the 'regulatory' position I will ask an electrician to...
