Oven and microwave wiring | on ElectriciansForums
Discuss Oven and microwave wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I
ionutmimi
Hi guys,a bit of help if u don t mind
I have to install a microwave and an oven .one is 3.2kw and other one 3.5kw
My plan is to run a 6 mm cable from the c u and and on the other end two double pole switches,one for each app.( both app will be built in in one of the kitchen unit)
Now from the switches to the app do i have to run same 6 mm cable or smaller one will do?
Or if anyone has better ideea ... Will be welcome
Thanx for your time lads
Reply to Oven and microwave wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
Most appliances come with a plug fitted if they are rated 13amp.or under. If not I would just fit a plug top. If it's rated greater than 3kw then...
