oven clocks/timers | on ElectriciansForums
Discuss oven clocks/timers in the Australia area at ElectriciansForums.net
OXFORD
Does anybody know where you can obtain a new clock /timer for a electrolux built in oven.The current one just flashes 1200 all the time,you cant set the time.Oven still works.
MANY THANKS
a read of the instructions is advised b4 spending on new. download from manufacturers web site. as spin says, you probably have to hold a button down. which one is anybody's guess. usually helps to have an 11 year old handy. they understand these things. if you are over 14, forget it.
I have a Electrolux oven and to set the time after the power has been off you need to turn off at isolator for 1 min then once turned back on it will flash for 30 seconds to allow you to set time, might be worth a try
Reply to oven clocks/timers in the Australia area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Oh I get that for sure. Here it's not the problem though. The oven is in very good condition, and works well, just the heating element is warped...
