A
adam.h
Customer is having 2 ovens, both rated at 3K55W each so 15.5A
Would the best way be to run two 2.5 radials on a 20A mcb or have them on a 4mm ring 32A breaker (or rad even to seperate them?)
Also, they are having an induction hob rated at 7K09W, 31A. Would sticking this on a 32A mcb be cutting it a bit fine? otherwise it's 10mm instead of 6mm.
