P
pushrod
Hi , looked at an oven this afternoon that had tripped its mcb 40A, on 10mm T&E, and on resetting it the oven did not work. However, fan and grill both still worked. Tested continuity across L and N at isolator - greater than 199 ohms with oven switched off and 127 ohms with dials turned on . I would have expected something much lower than this to get a large heating current to flow, even if it was only 3kW and i think it is more ,you would be looking at about 17 ohms?. Is it likely that the heating element has gone ?
Or could it be something else ?
It is a whirlpool oven - if it is the element are they cheap and easy to replace or is it better not to bother?
Also tested insulation resistance between L/N and earth and that was fine.
I have no experience of ovens so any comments welcome.
