B
Bright.Spark
Ive just taken over a nightmare job where a spark has walked off site. Its a kitchen but the electrician forgot the plug for the oven. The hob is gas but the oven needs pluging in. The problem is the kitchen has been fitted and the tiling has been done. Now there is a socket just to the right of the hob but the plug is too short plus it would mean cutting the counter and passing the plug through. There is however a socket in a cupboard in the next room can I drill through the wall behind the cuboards and use the socket in the other room and just label it up as oven?
This plug in the other room, is it used alot? Obvious? My own concern would be no local isolation because you'd have to go to the next room to isolate.
Is the socket in the other room on the same circuit as the sockets in the kitchen?
Cant you spur off socket in the other room... if isnt spurred already and bring the a supply into one of the units near to the oven - FCU in there, extending oven flex if need be ?
thing i'd do what synthai suggests FCU 2.5 to a Connection plate mounted next to the oven lable the FCU Oven
Just install a socket back to back with the one in the other room, and plug the oven in.
No need for an FCU.
No such requirement for local isolation. It does need to have a means of switching off and I'm guessing that the oven would include an integral function for switching off.
No need for an FCU.
If the circuit you are adding the socket to is already a spur then you will need an FCU ,as synthai has pointed out
No not really.
If the socket-outlet in the other room is an unfused spur, then an FCU would be required upstream to make the spur fused.
The oven could still be on a plug.
I thought ovens/cookers had to have Isolation switches above the worktop, or is this open to interpretation?
The rule is "accessible" and that in my eyes means visible!
And mine. Oh I do love "open to interpretation"
Dont get me wrong but most Regs are open to interpretation thats why there is so many "grey areas" and confusion in kitchens, the argument has been going on since part p was introduced.
Black and White I say, then no argument
:49:
Oven Plug
Bright.Spark,
Darkone,
