Oven supply question | Page 2 | on ElectriciansForums
Discuss Oven supply question in the UK Electrical Forum area at ElectriciansForums.net
Sussex
When our Victorian semi was tarted-up in the 1980s, the cooker circuit to the kitchen was ripped out but fortunately since we moved in in 2000 the oven we've been using (with the gas hob) has been OK on a 13A plug. That oven is now well past its best before, and the replacement the wife wants is specified as 3.2kW. The fuse rating quoted is 16A.
One of the 32A MCB's in the consumer unit feeds the sockets upstairs and the 4 in the kitchen (but not the rest of the ground floor). The maximum likely load upstairs at any one time is an electric blanket, a clock radio and a vacuum cleaner. In the kitchen, it's kettle, toaster, ordinary front-loading washing machine, bog standard fridge/freezer and the new oven.
Being dependant on my State Pension + benefits, I need to sort out the supply to this oven ASAP without dipping much more into what's left of my savings. Electrician A has quoted £270 incl VAT to run a new supply from the consumer unit to a cooker switch in the cupboard alongside the oven (but using mini trunking along the hall skirting rather than diving under the floor). Electrician B has quoted £60 incl VAT to add a 20A cooker switch to the existing kitchen ring main, on the basis that in practice we're never going to have all elements of the oven drawing max current at once, and if they ever did, worst case would be the MCB trips, which is no big deal.
I'm obviously keen on Plan B but ... is there a potential snag to it which isn't obvious to me?
Interesting what you guys are saying your day rates are. We're in East Sussex, just over the order from Kent, and from what I can gather from neighbours the going rate hereabouts seems to be more like £300 + VAT.
Well, this has turned out really interesting. Ignoring matey and his £60 bodge, we end up being quoted £308, £211 and £145. All three check out kosher, but only the highest-priced guy is VAT registered. My gut feeling about the other two is pretty much the same, so it's hard to think of a reason why we shouldn't go for the cheapest!
check with both the 2 cheaper quotes whether you will get:
1. installation certificate.
2. notification to LABC. this generally entails the spark to be niceic.napit, stroma etc.
IMO, £145 is way too cheap. the £211 sounds in the right price bracket.
Already checked and cheapest guy comes up 100%, established 1999 too. I have no idea how he makes a living at his prices, but that's his lookout :)
From my experience Quotes/estimates can vary dramatically
I have been shown estimates for electrical work by customers who have asked me to give them a second estimate for the work.
Board changes seem to vary pretty dramatically as does small works.
I get a feeling the very ‘high side’ quotes I see don’t really want the job.
For example £150 to put up a customer supplied pendant
I’m thinking the old cooker circuit that was removed in the past is still lurking somewhere under the kickboard or something.
If it’s in alright nick, could be reused ????
What did @Dan do with the optimistic button?
Having in the past completely rewired a two-bed bungalow and a one-bed flat, that was my inital plan but two things put the mockers on that. One is my arthritis, and t'other is my uncertainty as to whether it's still legal for me to do that.
You can do it but you have to contact building control to get permission and they will come and test it all for a small fee.
perfectly legal for you to do it yourself. as long as you are competent to do it. maybe get a friend or family member to assist where the arthritis is a problem. you would be technically out of order by not notifying to local building control, but nobody's ever been prosecuted for that. if they did, the courts would grind to a halt with thousands of cases backlogged. part pee......poo.
(disclaimer., the above s only my opinion and not to be used for evidential purposes in any court of law unless presided over by the Borg)
Reply to Oven supply question in the UK Electrical Forum area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
