Overcoming joists | Page 3 | on ElectriciansForums
Discuss Overcoming joists in the UK Electrical Forum area at ElectriciansForums.net
sparrrrk
Hi all,
Hopefully some bright spark can enighten me. Been asked to move a bathroom ceiling light fitting today. Not a difficult job however I can't gain access to ceiling void due to a functional bathroom directly above the bathroom where the work needs doing. Floor tiles are laid which the customer does not want removing.
From where the fitting is now to where it needs to be a joist is in the way. Does anyone know a trick to overcome this from below. Hopefully there's a trick of the trade I haven't come accross yet.
thanks
Reply to Overcoming joists in the UK Electrical Forum area at ElectriciansForums.net
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
  • Borrowed earth
    If mechanily protected would a 2.5 not suffice.you could manufacture metal conduit just to get...
  • Duplicate posts
    Any suggestions for avoiding the duplicate posts that keep happening? I'm trying to delete mine...
  • Duplicate posts
