overcurrent protection | on ElectriciansForums
Discuss overcurrent protection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
beaver74
come across a 32A circuit feeding 4 x 100w lamps fed via 6.00mm swa but at far end lighting is conected via 1.5mm flex .so in theory this cant over load 1.5 flex earth loop of .78 so can this be accipted as earth loop will clear fault under fault just as a 2.5mm t+e can be protected by a 32A breaker as max load will be 26A
if so can any one point me in the direction of the reg this is covered by
Reply to overcurrent protection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
Ye smaller board (containing the RCBO'S) will literally be next to the MEMSHIELD, And hence the 32A MCB be simply feeding power to a 32A RCBO I...
