Overhead cable advice | on ElectriciansForums
Discuss Overhead cable advice in the UK Electrical Forum area at ElectriciansForums.net
L
lazy-riders
Hi, I have a job where I need to get a 10mm single phase cable from farm house (not a working farm) to outbuilding for a solar pv installation. Client adamant he does not want cable in a trench and wants it overhead from gable end to gable end.
The distance is 22m, was thinking 10mm split concentric would be best option, but have never spanned a cable this size over this distance.
Any advice would be appreciated, is it feasible, i.e using centenary wire, any hints or tips.
Thank you.
split con. on a catenary would be OK, bearing in mind the height restrictions ( pedestrian or vehicles), are your calcs. worked out right? your catenary fixings would have to be sound for that sort of cable weight also.
The pull-out forces on a 22meter span of catenary with 10mm cable attached to it will be huge.
if the gable is brick you could use hilti chemical adhesive capsules and once set screw eye bolts in.
https://www.hilti.co.uk/anchor-systems/capsule-adhesive-anchors/r190
But then you have to worry of the tension/weight pulling the whole brick out.
Reply to Overhead cable advice in the UK Electrical Forum area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
