Overhead cables within fabric of building | on ElectriciansForums
Discuss Overhead cables within fabric of building in the Australia area at ElectriciansForums.net
J
jasew
A two storey extension has been built to side of a property. The supply is overhead lines which are clipped to the existing building with clamps on the ends from which the tails run to the meter.
The problem is these cables are now going to be above the ceiling of the ground floor extension (if left where they are).
I've told the occupier to speak to DNO as I'm unsure but believe that these cables and joints need to be accessable and not beneath a tiled first floor level.
I think I've done the right thing.
Any opinions ?
Jase
Thanks guys,
Do you know if I can contact the DNO on their behalf ?
I've been asked to wire the extension and con unit upgrade and I'd like to try and speed things up a little.
Jase
Reply to Overhead cables within fabric of building in the Australia area at ElectriciansForums.net
