L
lee staf
Hi
I am about to test a rewire of a bungalow and have started by taking readings at the CU, the problem is that testing for Psc i get a measurement but when i test Pfc i get open circuit >200Mohms suggesting no earth. I have an overhead supply but the suppliers head shows what looks to me as TNC-S? as there is a main earth conductor 16mm from MET to earth terminal attached to suppliers head on neutral side? When doing a quick test at socket readings of 128ohms taken. Should i treat this as TT system and stake or contact Supplier. All circuits are RCD protected on 17th Ed CU.
Any help would be much appreciated.
Cheers
Staf
Cheers
Staf
