Overload relay with aM fuse | on ElectriciansForums
Discuss Overload relay with aM fuse in the Talk Electrician area at ElectriciansForums.net
Jahn
Uk
Hi
Can we use an aM fuse with overload relay,?
If yes can an aM fuse protect the conductors from damage incase of short circuit
Since i suppose aM fuses are used only for motor protection and cable.
How will cable protection achieved when aM fuse is used with an overload relay
Please explain a bit.thanks
But will the aM fuse would work to protect the cable from damage during short circuit or a gG fuse would be a better option.
aM is only for motor protection .does it mean that it's not best to protect a conductor
That's why we test our circuits, so we can comply with disconnection times.
Most motor circuits will have a DOL starter that or some control that will provide OL protection, the reason they are refered to as the thermal overload is because they work on heat, a motor will draw more current on startup so a thermal overload will allow for this for a short amount of time, if overload lasts to long the DOL will disconect.
Reply to Overload relay with aM fuse in the Talk Electrician area at ElectriciansForums.net
As if my handle doesn’t give the biggest hint. The pod light above the winch is the one I’m referring to. I don’t foresee any issues with using a...
