At work there has been a problem I've been told about, small 1.8 Kw 3 phase fans tripping the overloads
I'm not really involved in this but I am interested......
The fans are run off Inverters and the OL's for any circuit are usually within the control panels, length of run is upto 35 metres max in SY screened at both ends for the motor and separate cables for monitoring the OL's on 24v ,cable screen at panel end, these are often within the same tray.
Generally they set the OL's to flc plus 10% as a maximum, and occasionally they have this tripping problem and they move the OL's to a new position closer to the fans as requested by the Engineer
I asked what the problem was and was vaguely told its a harmonic thing something to do with frequency,
(this did surprise me as I thought OL's are basically bimetallic strips)
And would moving the OL's nearer solve this issue?
I've looked this up and found nothing so far ???
Can anyone explain this in a bit more detail please
