Owl energy monitor and pvoutput.org | on ElectriciansForums
Discuss Owl energy monitor and pvoutput.org in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Scobo
Anyone managed to get an Owl to upload their generation data to pvoutput.org ?
The owl is connected to the AC output from the inverter and giving a reading pretty close to the inverter.
Im using pvbeancounter to upload the data but can't get it to upload as generation.
It only seems to work if set as consumption data.
Sorted !
Just wasn't giving pvbeancounter long enough to upload all the data.
It took 2.5 hours to read all the data from the Owl for the last 2 weeks. !!! :dizzy2:
Just to update this thread, I've swapped to a Current cost Optismart as the owl was giving inaccurate readings at lower power generations.
The owl is reading 185 watts this morning whereas the Envir display is showing 29 watts.
People wishing to monitor Solar systems without leaving a PC on 24-7 can use the following solution:
Optismart>EnviR>Netsmart>Router
The Optismart is very accurate in reading many solar generation meters.
Please see Current Costs suitable meters list before buying.
Has any one found a reliable way of directionally measuring imported power via a clamping system or alternative?
Most CT clamps only measure magnetism and not current direction.
Reply to Owl energy monitor and pvoutput.org in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I answered a similar question for the client, just looked at all the heaters (2KW per heater) and then asked for their half hour consumption...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
