P i r | on ElectriciansForums
  • Thread starter ryanryan
  • Start date
  • Replies 2
  • Views 1K
Discuss P i r in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
no but you need a thorough understanding of the subject above all else. its a legal document your putting your name to so be carefull.
Reply to P i r in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi If a new build has solar and battery fitted, but no paperwork or sign off has been completed, what are the implications? Do you need a mcs cert...
As long as the heat input is greater than the heat losses from the container and the resistance is sufficient to limit the current to no more than...
davesparks
