sambotc
Had to survey a job today for the first time, normally I install but times are hard so i'm on the ground!
Its a 4kw system, fitted onto a corrugated steel outbuilding roof approx 40 metres from the main house. SWA cable to be trenched in by customer, TNCS earthing from an over head supply.
My intention was to take a sub main off tails, into a 60A switched fuse, then 3 core 16mm SWA out to the outbuilding for minimal voltage drop and use 1 core to export TNCS, bonding the array and steel roof. Sheath to be earthed back at house only.
Is this acceptable given that the DNO ask for max 3 metre on tails?
Also, the pitch of the roof is very shallow approx 15 degrees, and I informed the customer that for optimal performance the array might have to be jacked up at the back to raise it up to more like 25. He didn't sound overly happy as it would cost more and was trying to tell me he is happy to put them on as is.
Where do I stand with the reg's on pitch, at the end of the day it's his investment at stake?
Being my first survey, i'm a little bit sceptical I have made the right decisions so suggestions welcome.
Cheers, Sam
Cheers, Sam
