Pain the backside job | on ElectriciansForums
Discuss Pain the backside job in the UK Electrical Forum area at ElectriciansForums.net
Birmingham
Evening all,
I went to a job this tonight to replace a socket that had supposedly blown the main fuse on the house. The energy supplier had been out to change fuse but refused to reconnect the house until this socket with an alleged earth fault had been replaced. The socket was wired correctly but it was cracked so I replaced it I also found other faults that I rectified. Then I tested the circuit but when it came to IR I was only getting 0.4Mohms, the house was built in the 70s and I’d say the electrics aren’t much younger if at all. I refused to sign off the electrics as safe and recommended a full rewire, leaving them with no power at all. I feel awful but in my opinion it wasn’t safe, what would you have done?
Cheers,
Phil.
1970s really isn’t that old (if the place was 1950s and full of rubber then yes it will need rewiring) but in this case just pull the fuse on the trouble circuit and offer to come back for further investigation
Think I would be in touch with them today and try to get a better resolution for them so that they have some power. Hopefully no children in the house? I have done the same however the main fuse had blown twice and the old wylex CUs' had rotted away exposing the innards and were hanging off the wall with low <1Mohm readings. Issued a danger notice which you did???
So would I , what is to stop them turning it back on themselves?
Was it still off when you got there ?
You have absolutely NO RIGHTS to do this ................ so hopefully you are back on site reconnecting them now.
as for the 0.4 mohms ................... sounds like something(s) are still connected.
Very poor approach ..........
In fairness the board refused to connect it back up.
0.4 M ohms......bet its either an rcd spur somewhere or appliance bringing the reading down
As long as its not heavily loaded, Pvc cabling from the 70's is absolutely fine and will probably be so for another 30 plus years yet
Recommend a rewire by all means if thats your feeling about the install, but leaving them with no power at all for a low IR on one circuit without investigating further....??
If they got another sparks in for a second opinion and he finds the cause is an appliance you've not unplugged etc your going to look bad
The home would have had other circuits .......... sure leave the faulty circuit disconnected ............ but everything? No
The only time I have made a customer have no electricity was an inspection after a fire ........ nearly all the cables were exposed, and the copper cores were exposed................. hardly safe to live in. The fire brigade and local services found them temporary alternative accommodation
Reply to Pain the backside job in the UK Electrical Forum area at ElectriciansForums.net
Its down to the budget and your experience level - If they cannot pay you cannot work, If you dont know whats safest you shouldn't work - If you...
I went to look at a job like this a few years ago. My customer had a rental house, where there was an upstairs bedroom that had a newly built stud...
    • Informative
