Pan connector to soil, not sure what needed plumbing advice | on ElectriciansForums
Discuss Pan connector to soil, not sure what needed plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Pan connector to soil, not sure what needed Hi all,
Need to change this pan con and am not sure what I'm looking at where the pan con and the soil meet? I'm guessing it's not just a regular one needed?
The piece of solid plastic pipe immediately after the flexible section ends looks a smaller bore than the soil sticking out from the tiles. And then there is a double lip between the two, presumably with a seal inside for push fit?
So I'm thinking the current pan con ends with plain pipe smaller than the soil which is designed to push into that specific brand of soil and vent? But could have that wrong.
Any advice/info would be appreciated
Pan connector to soil, not sure what needed to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Pan connector to soil, not sure what needed plumbing advice in the Plumbers Forums area at ElectriciansForums.net
P
Getting the right length pan connector for a toilet with plinth Hi all, We recently had to have our toilet pan replaced as the old one cracked...
pmcbgle
P
K
Connecting bath drainage to soil pipe Hi all, I need to connect my bath drainage to my new soil pipe. I have only one spare entry to boss into...
kristeva
K
