solar_newbie
Looking for some advice/opinion on the issue I am having with my solar installation.
I have 22 x 180w panels (I wont name the manufacturer) connected to a PVI-3.6-TL. The system was installed in April 2011 and was working fine up until roughly Nov 2012.
The inverter shows the error message RISO LOW and will not start up. The installers have been out on numerous occasions and have tried everything to resolve. They say this is usually caused by a faulty connector on the panels or damage to the DC cabling which when it rains or is damp will cause this to happen. They seemed to have resolved the issue but a few days later the same thing occurred. The installers returned in Feb 13 (it was an extremely sunny day) and replaced all the DC cabling and changed all the connectors on the panels, they also brought a different inverter just in case the one installed was making the wrong reading. Also as a precaution they earthed the frames as this had not been done previously.
After all of this the inverter still shows RISO LOW 0.7M!!
I decided to do some research into the issue and came across something interesting. My installation is in Folkestone, approx 2-3kM from the coast, does this mean that my panels are exposed to the salt from the sea and in the air?
Further research shows that the panels I have installed have been tested against this and passed up to 'severity 3', however almost every other panel I have checked recently are tested up to 'severity 6'. I am not too sure the difference but I would assume that 3 is less than 6 and that possibly my panels have corroded over the last 2 years to the point they do not work anymore?
I am thinking of writing to the manufacturer to see if this is possible and if I am covered for this, the installer is reluctant to change the panels until this is confirmed and they say the manufacturer does not accept the issue is their fault and says there will be a fault on the wiring side somewhere, we know this is not possible as I have watched everything being switched.
Anyone else have experience of this or advice on a solution?
