Panels Sizes..... | on ElectriciansForums
Discuss Panels Sizes..... in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
B
Berneray
Morning guys.....
Looking for some help.....
Quoting for a job on a garage roof. Couple looking for a 4kpw system.
However our usual panels are just slightly too wide....1082 by 1575.
We need to find a panel no bigger than 980 by 1575.
Any ideas...
Cheers
Depending on roof dimensions, sometimes you can achieve a higher kWP using a smaller panel - we have ET Solar 195W mono that are 1580X808mm.
ET 250W are 1640mmX992mm (also have stock of these, PM for prices if interested).
Would 20 Canadian Solar 200 Wp (4 kWp) fit on the roof. These are 80 cm wide and 158 cm long so would need a roof 8.6 x 3.8 m to fit on 20 panels
Reply to Panels Sizes..... in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
